Go Back   Chrysler 300 Forum - Forums and Owners Club! > Chrysler 300 Forum - Help Zone - Problems, Complaints, and Solutions > Chrysler 300 Mechanical Problems and Questions
Notices
Chrysler 300 Mechanical Problems and Questions Discuss any Chrysler 300 mechanical problems/questions in this forum. Engine, trans, supension, body, interior moving parts, interior/exterior trim panels, etc.
Latest Vendor News!
AutoAnything
Reply
Thread Tools
  #1
Old 02-24-2011, 08:48 PM
guynextdoor guynextdoor is offline
Chrysler 300 Forum Newcomer
Gender: Male
Vehicle: 300
Trim Level: Limited
Color: Brilliant Black
Rep:20
guynextdoor is on a distinguished road
Default P0016 - cam / crank Misalignment
i found alot of good info about my 300 on this forum...and I joined just to be able to share this with everyone
300 limited edition 3.5L engine:
I got a solid engine and traction control light on at the same time
did the key dance (thanks forum) and found it to be error code P0016 - cam / crank misalignment
126,000km - no warranty left
No cruise control, no downshifting on highway (limp mode ???)
longer than usual to start in the morning (winter -15C outside)
dealer replaced cam and crank sensor - lights came on again 2 minutes after leaving dealership ... $ 150.00
Got the 'well we have to start searching around to see what the problem could be' comment
Shortly after, they hooked it up again and drove it around - determined the misalignment was 16 degrees - suspect that belt skipped a tooth on a gear somewhere (normal alignment is +/- 3 degrees max)
NOTE: to anyone with this problem - get them to check the amount of misalignment before getting good parts replaced
dealership tells me its 5 hours to remove the everything to access the front of the engine
Fault: Leaking water pump - leaked engine coolant all inside the pulleys and belt
Inside looked like pink bubble gum everywhere; especially around crank pulley
they showed me the timing marks and it looked like 16 degrees out
All this gummed up coolant caused belt to skip tooth on a gear (probably crank pulley)
replaced water pump, belt, tensioner pulley and crank pulley
Cost $ 1,400.00
hope this helps anyone with the same problem
(great forum all !!)
__________________
Sponsored links
  #2
Old 02-25-2011, 02:36 PM
check6x's Avatar
check6x check6x is offline
Chrysler 300 Forum Member
Gender: Male
Vehicle: Dodge Charger SRT8
Vehicle Year: Gen1 - 2006
Trim Level: Charger SRT8
Color: Bright Silver
Rep:2106
check6x has a reputation beyond reputecheck6x has a reputation beyond reputecheck6x has a reputation beyond reputecheck6x has a reputation beyond reputecheck6x has a reputation beyond reputecheck6x has a reputation beyond reputecheck6x has a reputation beyond reputecheck6x has a reputation beyond reputecheck6x has a reputation beyond reputecheck6x has a reputation beyond reputecheck6x has a reputation beyond repute
Default
Thanks for the info. This is a V6 correct?
__________________
Sig by Sniper
Gasoline is a highly taxed drug
  #3
Old 02-25-2011, 07:31 PM
Gender: Male
Vehicle: 300
Trim Level: Limited
Rep:20
Default
yes V6....
__________________
  #4
Old 02-25-2011, 09:33 PM
NubNub's Avatar
NubNub NubNub is offline
Vehicle: 300 or so I was told
Trim Level: 300C
Color: Dark Lava Red
Rep:1121
NubNub has much to be proud ofNubNub has much to be proud ofNubNub has much to be proud ofNubNub has much to be proud ofNubNub has much to be proud ofNubNub has much to be proud ofNubNub has much to be proud ofNubNub has much to be proud ofNubNub has much to be proud of
Default
Wow crappy to hear it was a real issue and not a faulty sensor. How much coolant had you lost to cause all these issues?
__________________
  #5
Old 02-25-2011, 11:25 PM
Gender: Male
Vehicle: 300
Trim Level: Limited
Rep:20
Default
That's actually a really good point - I didn't notice loosing any coolant
Also, engine temperature was always OK
Also didn't see any coolant on my driveway (but not that I was specifically looking either)
The lights came on shortly after re-fueling one morning
If I was to speculate, maybe the heat of the engine gummed up the leak point eventually ? (again the crank pulley was covered in chunks of this pink looking gum)
The slow start in the morning may have been a clue - but i am a novice and just figured it was a result of the cold
the interesting thing is that out of 1000's of error codes - there isn't one for the water pump ??
Before knowing the 'key dance' - i took it to Canadian Tire - they told me the code but that their $10k computer wasn't sophisticated enough to give any specific details isolating the fault better (compared to Chrysler's $ 20k computer that gives more info ???)
So they started rhyming off all the possible causes including the ABS module and PCM, etc....
They actually said it would be best to take it to Chrysler as they would know better where to start diagnosing the problem - so that was $ 78 for getting the code from Canadian Tire...
that was before I knew about the key dance and that's when I started reading this forum...
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
MPG suffers after crank sensor install Quiet Lunatic Chrysler 300 General Discussion 9 01-22-2011 05:30 PM
300 wont crank vipertamer Chrysler 300 Mechanical Problems and Questions 5 05-01-2009 10:49 AM
Underdrive Crank Pulleys Explained tbyrne Chrysler 300 Performance Mods - Engine - Chrysler 300C SRT8 6 09-26-2008 02:13 PM
» Advertisement
vB.Sponsors
=Gigathreads Network=
DIESEL Diesel Forum
CHRYSLER Chrysler 300C Forum
JEEP Jeep Forum
PONTIAC Pontiac G8 Forum
