Go Back   Chrysler 300 Forum - Forums and Owners Club! > Custom Chrysler 300 - 300C - 300C SRT8 Performance and Mods Zone! - Custom 300C Mods. > Custom Chrysler 300 Interior Modifications - Audio / Video
Notices
Custom Chrysler 300 Interior Modifications - Audio / Video All mods on the interior of your Chrysler 300. Stereo Mods, Sub Boxes, Amps, Electronics, Shift Knobs, Upholstery, Trim Panels, Billet Parts and Accessories, etc.
Latest Vendor News!
AutoAnything
Reply
Thread Tools
  #1
Old 07-17-2010, 06:41 PM
sw houston tx sw houston tx is offline
Chrysler 300 Forum Newcomer
Gender: Male
Vehicle: 300
Trim Level: 300
Color: Brilliant Black
Rep:10
sw houston tx is on a distinguished road
Default radio wont turn on!!
hey fellas,
i have a 2006 base w/ no fog lights. so this morning, i came outside to go to work and turned on my car and tried to turn on my radio/screen but it is totally dead! i also noticed that the red idle light on my screen wasn't on. the light for my amp control was off also. so i opened my trunk and checked the fuse for my radio (cavity #36, fuse 20 amp yellow) and it was blown. i then opened my hood and fuse box and took the 20 amp yellow fuse from cavity 7 (fog lights) and put it in cavity #36. i turned my car on and the radio still wont turn on and didnt blow either. my fuse for the amp is still intact also. i really dont know whats wrong. any help is appreciated!!
__________________
Sponsored links
  #2
Old 07-17-2010, 07:03 PM
SHIPP's Avatar
SHIPP SHIPP is offline
Gender: Male
Vehicle: 300C
Trim Level: 300C
Color: Bright Silver
Rep:262
SHIPP is a jewel in the roughSHIPP is a jewel in the roughSHIPP is a jewel in the rough
Default
is it an aftermarket deck or stock? if aftermarket then possibly check the fuse on the back of the unit itself.
__________________
  #3
Old 07-17-2010, 07:07 PM
aawhyte's Avatar
aawhyte aawhyte is offline
Chrysler 300 Forum Member
Gender: Male
Vehicle: Spectre
Vehicle Year: Gen1 - 2007
Trim Level: Touring
Color: Steel Blue
Rep:475
aawhyte is a glorious beacon of lightaawhyte is a glorious beacon of lightaawhyte is a glorious beacon of lightaawhyte is a glorious beacon of lightaawhyte is a glorious beacon of light
Default
And also I would pull the HU out if it is aftermarket and check the wiring. It sounds like something shorted to make the fuse blow.
Worst case the HU died and while it was in it's last throws of life blew the fuse on the way out.
__________________
Alex, 07 Touring
MODS: Shifter Paddles, Kenwood DNX-6140, Infinity 6x9's, 4x75w Jensen Amp, Kicker 400.1ZX Amp and CVR12 Sub, Sirius, Console LED lights, 20% tint, beep module, Clear Side Markers and Lowered front license plate.
  #4
Old 07-17-2010, 07:19 PM
Quiet's Avatar
Quiet Quiet is offline
Gender: Male
Vehicle: 300
Trim Level: 300
Rep:0
Quiet is an unknown quantity at this point
Default
Both of those suggestions make a lot of sense, gents.
__________________
  #5
Old 07-17-2010, 07:40 PM
Gender: Male
Vehicle: 300
Trim Level: 300
Rep:10
Default
its an after market jensen flip-out screen. ohhhh i didnt think of checking the HU fuse. im going to check it right now. i hope everything is ok with the HU...sucks driving in a quiet car. thanks for the input guys
__________________
  #6
Old 07-17-2010, 08:14 PM
Gender: Male
Vehicle: 300
Trim Level: 300
Rep:10
Default
I checked the HU fuse and its still intact. Any other ideas guys?
__________________
  #7
Old 07-17-2010, 09:04 PM
aawhyte's Avatar
Gender: Male
Vehicle: Spectre
Trim Level: Touring
Color: Steel Blue
Rep:475
Default
Look in your manual and see if there is a way to "hard reset" the unit. Or even any reset. Try that. If that doesn't work and you have a multimeter or a test light I would check to see if your getting power to the HU on the power wires. Also check the radio ground wire.
Did you look at the wiring? Everything look ok? Check the car radio fuse, cavity #36, fuse 20 amp yellow, again to make sure it didn't blow again. If it did then you have a short in the power wires somewhere.
__________________
Alex, 07 Touring
  #8
Old 07-17-2010, 10:18 PM
Gender: Male
Vehicle: 300
Trim Level: 300
Rep:10
Default
okay, i got a hold of a multimeter and found the problem and now my HU is working perfectly. but now my subs dont hit!! everything is still connected and the amp is getting power but nothing is comin out of the subs. if its not one thing its another!
__________________
  #9
Old 07-18-2010, 01:02 AM
UC300C's Avatar
UC300C UC300C is offline
Gender: Male
Vehicle: 300
Trim Level: 300C
Rep:105
UC300C will become famous soon enoughUC300C will become famous soon enough
Default
Quote:
Originally Posted by sw houston tx View Post
....if its not one thing its another!
Man ain't that the truth when it comes to an electrical problem. Once you fix one thing, something else is messed up. Good luck, and like suggested, the best thing to do is take your multimeter and get to testing. Hope you find the problem. If it was a hard radio reset, you might try and see if the sub volume on the HU got turned down or even off, that may be why your not gettin any sound, even though the amp is on.
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
clacking/thumping/popping noise when I turn the key to turn the radio on... Chrysler300Black Chrysler 300 Mechanical Problems and Questions 10 09-13-2009 03:24 AM
2008 mirror with built in turn signal pin an color code needed orandaberg Chrysler 300 Electrical Problems and Questions 7 07-06-2009 04:34 PM
Installing a Removable Sirius Radio tcaley Chrysler 300 Electrical Problems and Questions 0 07-21-2008 03:11 AM
Connecting Aux audio sources to “REC” AM/FM/6 Disc Radio w/Nav using interface. ReggieD 1st Gen Chrysler 300 2 06-17-2008 10:26 AM
» Advertisement
vB.Sponsors
=Gigathreads Network=
DIESEL Diesel Forum
CHRYSLER Chrysler 300C Forum
JEEP Jeep Forum
PONTIAC Pontiac G8 Forum
