Go Back   Chrysler 300 Forum - Forums and Owners Club! > Custom Chrysler 300 - 300C - 300C SRT8 Performance and Mods Zone! - Custom 300C Mods. > Custom Chrysler 300 Interior and Exterior Lighting
Notices
Custom Chrysler 300 Interior and Exterior Lighting HID - HALO - LED LIGHTING - UNDERBODY LIGHTING - TINTED/SMOKED/PAINTED TAILS - ETC.
Latest Vendor News!
AutoAnything
Reply
Thread Tools
  #1
Old 03-23-2010, 10:45 AM
bravoco1010's Avatar
bravoco1010 bravoco1010 is offline
Chrysler 300 Forum Member
Vehicle: 300
Trim Level: Touring
Color: Inferno Red
Rep:247
bravoco1010 has a spectacular aura aboutbravoco1010 has a spectacular aura aboutbravoco1010 has a spectacular aura about
Question Removing and replacing side marker lights
I just purchased some smoked side markers on ebay... does anyone know how to replace those? Or direct me in the direction of a thread that will instruct me how to do it properly without damaging my car lol...
Thank you.
__________________
Sponsored links
  #2
Old 03-23-2010, 11:13 AM
Donnie1's Avatar
Donnie1 Donnie1 is offline
Vehicle: 300C Heritage
Trim Level: 300C
Color: Cool Vanilla
Rep:114
Donnie1 will become famous soon enoughDonnie1 will become famous soon enough
Default
Not sure if the touring is the same as the 300C but I just changed mine yesterday. The drivers s ide is alot more of a PIA than the passenger but all you do is:
For the drivers side; crank the wheel all the way to the left. You see 3 plastic push pins in the fender well on the front near along the bottom, remove those. You will also need to remove the first three 7mm screws along the bottom of the fascia. Once those are off, just pull down on the front of the black belly pan. Reach up in behind the fender and there will be a 1/2 inch nut, deep well socket needed, on the front side of the marker light, remove that and the light will pop out the side. Disconnect the light and place in new light. Reverse order of events.
For the passenger side: Exactly the same as the drivers side except there is no air silencer system in place to have to get in the way and you crank the wheel all the way to the right.
Hope this helps.
__________________
  #3
Old 03-23-2010, 11:40 AM
brannigan03's Avatar
brannigan03 brannigan03 is offline
Gender: Male
Vehicle: '11 Dodge Avenger Heat
Vehicle Year: Gen2 - 2011
Trim Level: Charger R/T
Color: Custom
Rep:1753
brannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant future
Send a message via AIM to brannigan03
Default
IMO, it's easier to just jack the car up and remove the belly pan. You will then be able to just reach up and access the bulb harness and nut the holds the sidemarker lens in.
__________________
  #4
Old 03-23-2010, 12:08 PM
HPNO300's Avatar
HPNO300 HPNO300 is offline
DFW LX CLUB Member
Gender: Male
Vehicle: 300 Touring and SRT8
Vehicle Year: Gen1 - 2009
Trim Level: 300C SRT8
Color: Custom
Rep:2291
HPNO300 has a reputation beyond reputeHPNO300 has a reputation beyond reputeHPNO300 has a reputation beyond reputeHPNO300 has a reputation beyond reputeHPNO300 has a reputation beyond reputeHPNO300 has a reputation beyond reputeHPNO300 has a reputation beyond reputeHPNO300 has a reputation beyond reputeHPNO300 has a reputation beyond reputeHPNO300 has a reputation beyond reputeHPNO300 has a reputation beyond repute
Send a message via Yahoo to HPNO300
Default
both methods that were mentioned are the best way to do it without removing the whole fascia and yes the 300 along with the 300c and srt sidemarkers are all the same...good luck!
__________________
  #5
Old 03-23-2010, 12:14 PM
300 Addict's Avatar
300 Addict 300 Addict is offline
Gender: Male
Vehicle: 2005 Chrysler 300 3.5 H.O
Vehicle Year: Gen1 - 2005
Trim Level: Touring
Color: Satin Jade
Rep:8733
300 Addict has a reputation beyond repute300 Addict has a reputation beyond repute300 Addict has a reputation beyond repute300 Addict has a reputation beyond repute300 Addict has a reputation beyond repute300 Addict has a reputation beyond repute300 Addict has a reputation beyond repute300 Addict has a reputation beyond repute300 Addict has a reputation beyond repute300 Addict has a reputation beyond repute300 Addict has a reputation beyond repute
Default
Quote:
That's how I ended up doing it.
__________________
-Paul
  #6
Old 03-23-2010, 01:05 PM
Quiet's Avatar
Quiet Quiet is offline
Gender: Male
Vehicle: 300
Trim Level: 300
Color: Bright Silver
Rep:0
Quiet is an unknown quantity at this point
Default
I did mine when I upgraded the grille and fogs so I had the fascia pulled off. That made it very easy to do.
Good Luck!
__________________
  #7
Old 03-23-2010, 05:37 PM
Nemo's Avatar
Nemo Nemo is offline
Vehicle: 2006 - 300
Trim Level: 300C
Color: Brilliant Black
Rep:3901
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Default
No no no no no, easiest is thru the wheel well who's got time to jack the car up lol
__________________
Courtesy of Sniper
<a href=http://i47.tinypic.com/34rtztd.jpg target=_blank>http://i47.tinypic.com/34rtztd.jpg</a>
  #8
Old 03-23-2010, 05:41 PM
Gender: Male
Color: Custom
Rep:1753
Default
Quote:
Actually now that I think about it...I took the belly pan off and installed my lights without jacking the car up...
__________________
  #9
Old 03-23-2010, 10:17 PM
dmighty's Avatar
dmighty dmighty is offline
Gender: Male
Vehicle: 2007 Chrysler
Vehicle Year: Gen1 - 2007
Trim Level: 300C
Color: Silver Steel
Rep:503
dmighty is a glorious beacon of lightdmighty is a glorious beacon of lightdmighty is a glorious beacon of lightdmighty is a glorious beacon of lightdmighty is a glorious beacon of lightdmighty is a glorious beacon of light
Default
Either way, its a PIA but you will appreciate the enhancement. I did as others stated by turning the wheel in one direction and remove the push pins and screws and pulling down on the belly pan and reaching in. It wasn't fun and i dreaded the day the bulb went and had to be replaced. You have been given the best advice.
Good luck
__________________
  #10
Old 11-26-2012, 01:01 AM
industryman industryman is offline
Chrysler 300 Forum Newcomer
Gender: Male
Vehicle: 300
Vehicle Year: Gen1 - 2006
Trim Level: 300C
Color: Magnesium
Rep:10
industryman is on a distinguished road
Default Replacing side marker lights on 300C
I read the forum thread and the advice was great. I tackled the job and learned quickly that removing the front belly pan with the car jacked up ws the easiest way to get to the side marker lights. As noted, the driver side is harder but I was able to reach both lights from below, remove the harness plug, turn the light socket out of the base and change the lights WITHOUT REMOVING THE LENS FROM THE BODY! Getting to the 1/2" nut on the back of the lens fixture is really a PIA. I'm not sue why the owners manual says to use a W5W bulb but a standard 194 ws in the socket and works.
Thanks for the forum's advice and I hope this helps others.
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Advertisement
vB.Sponsors
=Gigathreads Network=
DIESEL Diesel Forum
CHRYSLER Chrysler 300C Forum
JEEP Jeep Forum
PONTIAC Pontiac G8 Forum
