Go Back   Chrysler 300 Forum - Forums and Owners Club! > Chrysler 300 Forum - Help Zone - Problems, Complaints, and Solutions > Chrysler 300 Mechanical Problems and Questions
Notices
Chrysler 300 Mechanical Problems and Questions Discuss any Chrysler 300 mechanical problems/questions in this forum. Engine, trans, supension, body, interior moving parts, interior/exterior trim panels, etc.
Latest Vendor News!
AutoAnything
Reply
Thread Tools
  #1
Old 12-06-2009, 04:22 AM
CALI300's Avatar
CALI300 CALI300 is offline
Chrysler 300 Forum Member
Gender: Male
Vehicle: 300
Trim Level: Touring
Color: Custom
Rep:60
CALI300 will become famous soon enough
Exclamation Need Help and Suggestions car shutting off.
Hey how are you guys doing? I need some serious help. I have a 2007 Chrysler 300 touring 3.5L . It has 49k miles on it, and today I changed my spark plugs. I bought the E3 diamondfire spark plugs from Kragens to replace the factory spark plugs. I installed them and made sure everything was plugged in correctly. Then I reset the battery and tried starting up my car. First it made a funny sound and the RPM's were at .500 and then it jumped to 3000 and was being very loud as it idled. A loud noise was coming from the intake manifold like a loose hose but nothing was loose. I let the car run for a minute and it made a odd sound and it shut itself off. I started the car back up and drove it for a while, the E3 spark plugs really made a huge difference i could feel the power gains as well as impressive throttle response. Whenever i had to stop at a red light or a stop sign a red lightning bolt would flash on my dash and the car would immediately shut off on me. As i merged off the freeway i was going about 40mph as i slowly applied the brakes and the red lighting bolt started flashing, immediately the car lost traction and I slid off the road. Luckily I didn't hit anything. The car ran decent but when it idles or I have to stop for anything more than 5-10 seconds the light flashes and the car immediately turns off on me. The check engine light has just come on and I used a OBD-2 reader to read it and it came up with P0507, which is something with throttle body or idle too high. I removed the E3 spark plugs and put in my old stock ones, but the car still shuts itself off after I idle for 5-10 seconds. Its idling about 300-600 RPM's more than normal and it sounds rough. I removed these also and then bought BOSCH platinum spark plugs which they recommend to me and then installed these, and my car is still flashing the red lighting bolt on idle or when i stop or I'm not moving or pressing on the accelerator. and then it cuts off immediately Now my engine light is saying 2 misfires when i ran diagnostics again. My car isnt running good at all Im scared to even start it. I have a stage 2 AFE cold air intake, and flowmaster exhaust, i don't know if that makes a difference. I'm really screwed right now someone please help me out with anything. I really appreciate it
__________________
Sponsored links
  #2
Old 12-06-2009, 08:23 AM
Peter Parker Peter Parker is offline
Chrysler 300 Forum Newcomer
Vehicle: 300
Trim Level: 300C SRT8
Color: Brilliant Black
Rep:38
Peter Parker is on a distinguished road
Default
The car is misfiring when the lightning bolt flashes, what misfire codes did you see? A generic P0300 or P0301-P0306 (specific cylinders)? Prior to replacing the stock spark plugs did you have any of these problems? If not, I'ld really double check all the electrical wires and vacuum lines to make sure something didn't get swapped or messed up in the replacement plug install. Stock throttle body, correct?
__________________
Lopey: 473rwhp/439tq - 6.1L N/A Modified
Best ET 11.152@117.5 / Trap Speed - 126.15
  #3
Old 12-06-2009, 11:51 AM
Cibalo's Avatar
Cibalo Cibalo is offline
Gender: Male
Vehicle: 300C SRT8
Vehicle Year: Gen1 - 2006
Rep:5865
Cibalo has a reputation beyond reputeCibalo has a reputation beyond reputeCibalo has a reputation beyond reputeCibalo has a reputation beyond reputeCibalo has a reputation beyond reputeCibalo has a reputation beyond reputeCibalo has a reputation beyond reputeCibalo has a reputation beyond reputeCibalo has a reputation beyond reputeCibalo has a reputation beyond reputeCibalo has a reputation beyond repute
Default
yeah it sounds like the ITA sensor or something like that got unplugged. Easy to do when changing things out and a harness is in your way
__________________
  #4
Old 12-06-2009, 12:26 PM
Quiet's Avatar
Quiet Quiet is offline
Gender: Male
Vehicle: 300
Trim Level: 300
Color: Bright Silver
Rep:0
Quiet is an unknown quantity at this point
Default
Check all the sensor plugs to make sure they are all in place and snug.
Most P05xx codes, if not due to a faulty sensor circuit, can be caused by the idle air control motor and in those cases, it is usually replaced if they find no electrical continuity across the motor leads.
__________________
  #5
Old 04-22-2014, 02:10 AM
red13142004 red13142004 is offline
Gender: Male
Vehicle: 300
Vehicle Year: Gen1 - 2007
Trim Level: Touring
Color: Cool Vanilla
Rep:10
red13142004 is on a distinguished road
Default
same problem. Did you fix it??
__________________
  #6
Old 05-05-2014, 03:13 AM
Shunniebunnie Shunniebunnie is offline
Gender: Female
Vehicle: 300
Vehicle Year: Gen1 - 2010
Trim Level: Touring
Rep:10
Shunniebunnie is on a distinguished road
Default
Hello everyone I'm New and I don't know how to start a thread and I need Help!! I have a 2010 Chrysler 300 Touring and my accelerator fell off today yes fell off while driving. Thank God nobody was hurt but has any one else had this problem before?
__________________
  #7
Old 05-05-2014, 03:15 AM
Gender: Female
Vehicle: 300
Trim Level: Touring
Rep:10
Default
I had the same problem misfire in the number 5 plug well burns out I had a warped cylinder head. Hope this helps
__________________
  #8
Old 05-12-2014, 10:41 PM
RockHemi's Avatar
RockHemi RockHemi is offline
Gender: Male
Vehicle: 300 C
Trim Level: 300C
Color: Magnesium
Rep:10
RockHemi is on a distinguished road
Default
I would Run stock plugs.
__________________
Roch
Reply
Bookmarks
Tags
spark plugs
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Advertisement
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
vB.Sponsors
=Gigathreads Network=
DIESEL Diesel Forum
CHRYSLER Chrysler 300C Forum
JEEP Jeep Forum
PONTIAC Pontiac G8 Forum
