Go Back   Chrysler 300 Forum - Forums and Owners Club! > Chrysler 300 Forum - Help Zone - Problems, Complaints, and Solutions > Chrysler 300 Electrical Problems and Questions
Notices
Chrysler 300 Electrical Problems and Questions Discuss any Chrysler 300 interior/exterior electrical problems/questions in this forum. Lighting, stereo, power windows, etc.
Latest Vendor News!
AutoAnything
Reply
Thread Tools
  #1
Old 04-04-2009, 03:50 PM
silversurfer silversurfer is offline
Chrysler 300 Forum Newcomer
Vehicle: 300
Trim Level: Limited
Color: Bright Silver
Rep:10
silversurfer is on a distinguished road
Default no fm radio signal
Hi, I searched and found absolutely nothing that can point me in the right direction of this problem. First, jsut to get it out of the way...my windows are not tinted. All of sudden I lost all fm signal to the stock radio. The am works fine so I am guessing this is an antenna issue. So the antenna in the window runs and plugs into the back of the deck correct? I just want to be sure to start looking there before I start ripping the console off. Any other suggestions that could help in this issue would be greatly appreciated
__________________
Sponsored links
  #2
Old 04-04-2009, 03:53 PM
mjr5150's Avatar
mjr5150 mjr5150 is offline
freshly blown
Gender: Male
Vehicle: 300
Vehicle Year: Gen1 - 2006
Trim Level: 300C SRT8
Color: Silver Steel
Rep:6700
mjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond repute
Default
I would look behind the deck . Seems like it came disconnected . WHat stock deck do you have ?
__________________
MagnaCharger MP2300 TVS Supercharger , Hemituner/AJ Dynotuned ,Hemi shop P & P heads, FRI Tomahawk Cam ,Dynatech LT headers w/hi-flow cats ,Corsa cat-back exhaust ,LMI full 4'' fendermount CAI ,Protorque 3400 stall TC ,Getrag 09 LSD , PP tranny & valvebody ,Arrington 85MM ported TB w/ Nitrous ports , BT catch can ,Hotchkis front & rear sways , MHT LLC 22'' performance sapping shoes wrapped lovingly in pirelli's,tinted tails & side markers,22 Elite leather door inserts & console cover,F'n halos,LED rear wing,PB 11.25 @ 125.16 - Stock Bottom 6.1L blown (10lbs boost)
  #3
Old 04-04-2009, 03:55 PM
Vehicle: 300
Trim Level: Limited
Rep:10
Default
Its the 6-disc cd changer and cassette deck...not the nav deck
__________________
  #4
Old 04-04-2009, 04:00 PM
mjr5150's Avatar
freshly blown
Gender: Male
Vehicle: 300
Color: Silver Steel
Rep:6700
Default
Are you still under warranty by chance if it's not super easy to fix ? Have you ever had to pull your bezel and remove the radio before ? It's very easy . Bezel pulls out from bottom and radio is held in with 4 screws .
__________________
  #5
Old 04-04-2009, 04:11 PM
Vehicle: 300
Trim Level: Limited
Rep:10
Default
Yeah i was just looking to see ho to remove it. Thanks for speeding that step up. The car has an extended warranty through the dealer I bought it from, but dealing with those in the past, I doubt they will cover it. I guess if its not an easy fix...aftermarket deck is closer to the horizon than planned.
__________________
  #6
Old 04-04-2009, 04:24 PM
GhostMan's Avatar
GhostMan GhostMan is offline
Gender: Male
Vehicle: Eragon
Vehicle Year: Gen1 - 2005
Trim Level: 300C
Color: Custom
Rep:1215
GhostMan has much to be proud ofGhostMan has much to be proud ofGhostMan has much to be proud ofGhostMan has much to be proud ofGhostMan has much to be proud ofGhostMan has much to be proud ofGhostMan has much to be proud ofGhostMan has much to be proud ofGhostMan has much to be proud of
Default
Quote:
I am not sure on the 300 I would have to go out and check. There should be a plug on the back window also running to the antenna. Make sure it is not loose. There is a plug for the defroster and should be one for radio. You may have to remove back deck to see. Pretty easy if so.
Fold seats down.
Pull side seats forward
pop side molding loose
pull deck towards you.
should be just one plastic rivet dead center behind seats.
Will just pull out then.
Pretty simple no tools needed. This is if you can not see the antenna connect.
__________________
  #7
Old 04-04-2009, 07:23 PM
Nemo's Avatar
Nemo Nemo is offline
Vehicle: 2006 - 300
Trim Level: 300C
Color: Brilliant Black
Rep:3901
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Default
Might be a simple antenna plug connector coming loose on the back of the radio. fyi to take the antenna completely out, you need to push it in to the radio and squeeze the metal surround on the antenna and pull it out.
__________________
Courtesy of Sniper
<a href=http://i47.tinypic.com/34rtztd.jpg target=_blank>http://i47.tinypic.com/34rtztd.jpg</a>
  #8
Old 04-04-2009, 07:27 PM
Quiet's Avatar
Quiet Quiet is offline
Gender: Male
Vehicle: 300
Trim Level: 300
Rep:0
Quiet is an unknown quantity at this point
Default
Look under the rear package tray for the connection there. And you'll want to check the back of the head unit. I suspect it's one of those connections.
__________________
  #9
Old 04-11-2009, 12:05 PM
Vehicle: 300
Trim Level: Limited
Rep:10
Default
alright i had some time this morning and removed the radio and unplugged / re-plugged and everything up there seems good....now i moved on to try and remove the rear deck...how the hell? I folded the seats down, removed the plastic rivot....the sides of the seat seemed like they needed to be removed so i removed the 10mm bolt that holds that piece on through the bracket, now the top seems to have a strap holding it in place. any tips on thios would be great
okay i figured out how to remove the deck but now i dont see an antenna or defrost connection....anyone know exactly where this connection is?
__________________
  #10
Old 04-11-2009, 12:22 PM
mjr5150's Avatar
freshly blown
Gender: Male
Vehicle: 300
Color: Silver Steel
Rep:6700
Default
Slide a straight screw driver straight down ( between the back of the bolster and the metal) the center on the top of the side bolsters and push down . You will push down on a release spring type clamp that is holding you in . You need to pull out( towards you ) on the top of it at the same time .
Look at the pics in here,,,,
Courtesy of Damien ( this is his hairy nasty pasty white arm )
This is the sucker giving you all the problems.....
From Damiens ( Ds300C) thread ................
http://www.300cforumz.com/showthread.php?t=60011
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Sirius - Acquiring Signal... dhbgl1800 Chrysler 300 Electrical Problems and Questions 2 03-06-2009 06:29 PM
Question from a noob eddiez06 Chrysler 300 Mechanical Problems and Questions 10 10-04-2008 05:10 PM
Installing a Removable Sirius Radio tcaley Chrysler 300 Electrical Problems and Questions 0 07-21-2008 03:11 AM
Connecting Aux audio sources to “REC” AM/FM/6 Disc Radio w/Nav using interface. ReggieD 1st Gen Chrysler 300 2 06-17-2008 10:26 AM
» Advertisement
vB.Sponsors
=Gigathreads Network=
DIESEL Diesel Forum
CHRYSLER Chrysler 300C Forum
JEEP Jeep Forum
PONTIAC Pontiac G8 Forum
