Go Back   Chrysler 300 Forum - Forums and Owners Club! > Chrysler 300 Forum - Help Zone - Problems, Complaints, and Solutions > Chrysler 300 Mechanical Problems and Questions
Notices
Chrysler 300 Mechanical Problems and Questions Discuss any Chrysler 300 mechanical problems/questions in this forum. Engine, trans, supension, body, interior moving parts, interior/exterior trim panels, etc.
Latest Vendor News!
AutoAnything
Reply
Thread Tools
  #1
Old 03-23-2009, 12:11 PM
tbyrne's Avatar
tbyrne tbyrne is offline
Vehicle: 300
Trim Level: 300C SRT8
Color: Bright Silver
Rep:376
tbyrne is just really nicetbyrne is just really nicetbyrne is just really nicetbyrne is just really nice
Default Is Your Transmission Leaking Fluid? Step inside!
It looks like alot of people have the dreaded transmission fluid leak. It's coming from the connector guide bushing on the passenger's side of the transmission. There is a technical service bulletin (TSB) for this but it usually isn't covered if the vehicle is outside the warranty period for time or mileage. The part # for the replacement part is 68021352AA. It lists for $8.95. I had to replace one of these over the weekend so I snapped a few pics so the "do it yourselfers" know what is involved. Please note, this was done on an SRT8 that didn't have the plastic belly pan installed.
New part -
Location on the transmission -
That little white tab in the 11:00 position rotates down to about 7:00. This will allow you to unplug the plug going into it. There is a 7mm bolt on the inside. Loosen that. It's part of the guide so it doesn't come out.
Gentally slide the connector guide bushing out of the transmission. Be prepared to catch the fluid that will come out when you do that. I didn't measure it but it's probably about a pint. Keeping track of how much you lose will allow you to replace it with the correct amount later. These cars don't have dipsticks. Put a little fluid on the two bushings on the new guide, slide it into the transmission. Your going to have to push it all the way down or the bolt inside won't bite. Tighten that, put the plug back in, lock it into place and your done underneith. You will need to head under the hood to take care of the fluid that you lost. All set after that!
Hope this helps!
Tom
__________________
Sponsored links
  #2
Old 03-23-2009, 12:34 PM
pd300c's Avatar
pd300c pd300c is offline
Gender: Male
Vehicle: 300
Vehicle Year: Gen1 - 2006
Trim Level: 300C
Color: Brilliant Black
Rep:2210
pd300c has a reputation beyond reputepd300c has a reputation beyond reputepd300c has a reputation beyond reputepd300c has a reputation beyond reputepd300c has a reputation beyond reputepd300c has a reputation beyond reputepd300c has a reputation beyond reputepd300c has a reputation beyond reputepd300c has a reputation beyond reputepd300c has a reputation beyond reputepd300c has a reputation beyond repute
Default
Dam good write up Tom I hope I never have to use it though!
__________________
  #3
Old 03-23-2009, 12:52 PM
mjr5150's Avatar
mjr5150 mjr5150 is offline
freshly blown
Gender: Male
Vehicle: 300
Color: Silver Steel
Rep:6700
mjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond reputemjr5150 has a reputation beyond repute
Default
Great write up Tom . I've always heard about the TSB for this but the pictoral was a nice touch . Thank you ,
__________________
MagnaCharger MP2300 TVS Supercharger , Hemituner/AJ Dynotuned ,Hemi shop P & P heads, FRI Tomahawk Cam ,Dynatech LT headers w/hi-flow cats ,Corsa cat-back exhaust ,LMI full 4'' fendermount CAI ,Protorque 3400 stall TC ,Getrag 09 LSD , PP tranny & valvebody ,Arrington 85MM ported TB w/ Nitrous ports , BT catch can ,Hotchkis front & rear sways , MHT LLC 22'' performance sapping shoes wrapped lovingly in pirelli's,tinted tails & side markers,22 Elite leather door inserts & console cover,F'n halos,LED rear wing,PB 11.25 @ 125.16 - Stock Bottom 6.1L blown (10lbs boost)
  #4
Old 03-23-2009, 01:11 PM
HEMIPHIL's Avatar
HEMIPHIL HEMIPHIL is offline
Bagged & Dragged :)
Gender: Male
Vehicle: SINISTER STEEL
Color: Silver Steel
Rep:4361
HEMIPHIL has a reputation beyond reputeHEMIPHIL has a reputation beyond reputeHEMIPHIL has a reputation beyond reputeHEMIPHIL has a reputation beyond reputeHEMIPHIL has a reputation beyond reputeHEMIPHIL has a reputation beyond reputeHEMIPHIL has a reputation beyond reputeHEMIPHIL has a reputation beyond reputeHEMIPHIL has a reputation beyond reputeHEMIPHIL has a reputation beyond reputeHEMIPHIL has a reputation beyond repute
Default
I have to get mine done. I noticed a small amount of fluid during the winter, when I shifted my ride around in the storage garage. Looking to get this done this week. I met a really good mechanic last week (that works for Chrysler...he's very well know over on LXF...fargo59), so he's going to be the only mechanic to wrench on my ride. I bought an extended warranty, just don't know if this is covered or not. It's getting done regardless. Thanks for the pic's Tom.
__________________
DD: 2005 Inferno Red Dodge Magnum RT
  #5
Old 03-23-2009, 01:55 PM
tugbone's Avatar
tugbone tugbone is offline
Chrysler 300 Forum Junior Member
Gender: Male
Vehicle: 2007 300c
Vehicle Year: Gen1 - 2007
Trim Level: 300C
Color: Inferno Red
Rep:10
tugbone is on a distinguished road
Default
Mine was just done under warr at 27000
__________________
  #6
Old 12-12-2009, 01:41 AM
midnitechrysler's Avatar
midnitechrysler midnitechrysler is offline
Chrysler 300 Forum Member
Gender: Female
Vehicle: 300
Trim Level: AWD Touring
Color: Midnight Blue
Rep:128
midnitechrysler will become famous soon enoughmidnitechrysler will become famous soon enough
Send a message via AIM to midnitechrysler Send a message via Skype™ to midnitechrysler
Default
i just did mine and now my check engine light is on but the car seems to be running good if not better than before. does that usually happen and will it go away or do i need to reset it?
__________________
Sig done by Quiknen
  #7
Old 12-12-2009, 09:12 PM
brannigan03's Avatar
brannigan03 brannigan03 is offline
Gender: Male
Vehicle: '11 Dodge Avenger Heat
Vehicle Year: Gen2 - 2011
Trim Level: Charger R/T
Color: Custom
Rep:1753
brannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant futurebrannigan03 has a brilliant future
Send a message via AIM to brannigan03
Default
Excellent write-up. Mine was done under warranty sometime last winter.
__________________
  #8
Old 12-16-2009, 05:06 PM
1 Bad Snake's Avatar
1 Bad Snake 1 Bad Snake is offline
Gender: Male
Vehicle: 300 C with SRT 8 Options
Trim Level: 300C
Color: Steel Blue
Rep:1421
1 Bad Snake has much to be proud of1 Bad Snake has much to be proud of1 Bad Snake has much to be proud of1 Bad Snake has much to be proud of1 Bad Snake has much to be proud of1 Bad Snake has much to be proud of1 Bad Snake has much to be proud of1 Bad Snake has much to be proud of1 Bad Snake has much to be proud of1 Bad Snake has much to be proud of
Default
If you have the predator reset it, doesn't hurt to try that first. If not pull fuse 11 if you have a 2007 or earlier, not sure what it is on 2008 and after.
Quote:
__________________
Magnaflow Higflows and Catback, Predator, Airhammer, Pedders suspension. Proudly supporting the Z.
  #9
Old 01-11-2010, 10:50 PM
TALLA's Avatar
TALLA TALLA is offline
Gender: Male
Vehicle: Black Pearl
Trim Level: 300C
Rep:1373
TALLA has much to be proud ofTALLA has much to be proud ofTALLA has much to be proud ofTALLA has much to be proud ofTALLA has much to be proud ofTALLA has much to be proud ofTALLA has much to be proud ofTALLA has much to be proud ofTALLA has much to be proud ofTALLA has much to be proud of
Send a message via MSN to TALLA
Default
where did you pick up that part ? looking for that online but cant find it need it for 300C
__________________
click picture for modlist
  #10
Old 01-12-2010, 03:32 PM
Gender: Male
Color: Custom
Rep:1753
Default
Quote:
Part # is 68021352AA as stated in the first post. You should be able to pick it up at your local dealership, it's a fairly inexpensive piece.
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2005 Touring Transmission fluid level check shawntmartin Chrysler 300 Mechanical Problems and Questions 12 04-04-2011 05:56 PM
When is it time to change Transmission Fluid and Antifreeze impala11419 Detailing and General Maintenance Forum 28 03-19-2009 01:04 PM
» Advertisement
vB.Sponsors
=Gigathreads Network=
DIESEL Diesel Forum
CHRYSLER Chrysler 300C Forum
JEEP Jeep Forum
PONTIAC Pontiac G8 Forum
