Go Back   Chrysler 300 Forum - Forums and Owners Club! > Chrysler 300 Forum - Help Zone - Problems, Complaints, and Solutions > Chrysler 300 Electrical Problems and Questions
Notices
Chrysler 300 Electrical Problems and Questions Discuss any Chrysler 300 interior/exterior electrical problems/questions in this forum. Lighting, stereo, power windows, etc.
Latest Vendor News!
AutoAnything
Reply
Thread Tools
  #1
Old 10-29-2008, 12:15 PM
tadracket tadracket is offline
Chrysler 300 Forum Newcomer
Vehicle: 300
Trim Level: Touring
Color: Brilliant Black
Rep:10
tadracket is on a distinguished road
Default Two problems - Speedometer / Voltage light
Good morning all. I have a couple things I need to fix on my '05. It has 118,000 miles on it and I planned on changing the battery very soon. My lights in the morning, especially when it is cold out, flicker at a pretty constant rate of 1.5-2 times per second. I do understand there is a bulletin out on this and the puter may need flashed. But on the way to work this morning, I got caught in terrible traffic. So I rolled from radio to cd mode and started jamming some metal tunes. Last week I installed a 12" RockFos P3 and a 640 watt Pioneer. It does ok I guess, definitley helped out the 4 speaker stock system. All of a sudden, my voltage light comes on. The car ran fine for the next 30 minutes to work, I shut the stereo off as soon as the light came on.
My question is, What seems to be the majority issue that causes this light to come on? Week battery? Week alternator? Something even more serious that would require a dealer to step in ?
My second question is with the speedometer. It does not work. But the mileage does. Any thoughts?
Thanks for any thoughts or ideas any of you fine folks may have. One day I will post some pics of my car. I almost have everything together to do a carputer. This car may not be a power house, but I love it anyway.
__________________
Sponsored links
  #2
Old 10-29-2008, 01:21 PM
stillbad's Avatar
stillbad stillbad is offline
Gender: Male
Vehicle: 2006
Trim Level: 300C
Rep:4013
stillbad has a reputation beyond reputestillbad has a reputation beyond reputestillbad has a reputation beyond reputestillbad has a reputation beyond reputestillbad has a reputation beyond reputestillbad has a reputation beyond reputestillbad has a reputation beyond reputestillbad has a reputation beyond reputestillbad has a reputation beyond reputestillbad has a reputation beyond reputestillbad has a reputation beyond repute
Default
I am no expert on either of these problems but since you installed the stereo gear last week sounds like you could have taped into something you shouldn't have or needs to be hooked up different.
Shawn ( Blowndakrt) is the expert here so he will more than likely be able help you..
__________________
  #3
Old 10-29-2008, 01:43 PM
Ultimatecarman45's Avatar
Ultimatecarman45 Ultimatecarman45 is offline
Gender: Male
Vehicle: SUPER BEE
Trim Level: Charger SRT8
Color: Linen Gold
Rep:6970
Ultimatecarman45 has a reputation beyond reputeUltimatecarman45 has a reputation beyond reputeUltimatecarman45 has a reputation beyond reputeUltimatecarman45 has a reputation beyond reputeUltimatecarman45 has a reputation beyond reputeUltimatecarman45 has a reputation beyond reputeUltimatecarman45 has a reputation beyond reputeUltimatecarman45 has a reputation beyond reputeUltimatecarman45 has a reputation beyond reputeUltimatecarman45 has a reputation beyond reputeUltimatecarman45 has a reputation beyond repute
Default
There could be a few items wrong. Most of them easy to test.
Most auto places can test batteries and alternators pretty easy. There has to be a voltage regulator of sorts on the car but I'm betting it's integrated in with something else.
It sounds like either you're battery or alternator isn't up to snuff though and isn't producing enough power at idle, and the sub/amp exposed it.
As for the speedometer, the mileage isn't linked to it by cable anymore, it is all digital now. Either the gears in the cluster are misaligned or broken, or something is wrong with the harness for that item.
__________________
  #4
Old 10-30-2008, 09:26 AM
Vehicle: 300
Trim Level: Touring
Rep:10
Default
Ouch. The speedo problem sounds like something I may let the dealer hack in to.
I failed to mention all this was going on before I installed the amp and sub, except the voltage light. That is new. But I went out last night to go home and when I fired up the car, the light was off. I went ahead and bought an Optima Red at Sam's Club last night. I'll get that installed this evening and see if the flickering goes away. I am also planning on doing the Big 3 mod. Just for piece of mind. My amp wire is bigger than what Chrysler is running on the ground wire and rear fuse block. :-)
Thanks guys for the input.
__________________
  #5
Old 11-21-2008, 07:07 PM
rawrods's Avatar
rawrods rawrods is offline
Vehicle: 300
Trim Level: 300C
Rep:91
rawrods will become famous soon enough
Default
Iíve also have lights flickering. When driving around 1500 RPM'S the lights will start to flicker like crazy. Its done this ever since I got the car (05 300c). I even took the car into have it checked and they didnít find anything wrong but guess what it still does it around 1500 RPM'S. Iím starting to think its in the alt because that's the only thing moving with the RPM'S. I will not know until I change it but It donít do it at 1400 or at 1600 and up so that just my 2 cents and yes Ive checked all the ground and fuses.
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
The ULTIMATE (almost) light bulb comparison thread (w/pics!) NautcaSprt6 Custom Chrysler 300 Interior and Exterior Lighting 76 12-11-2011 05:05 PM
Question from a noob eddiez06 Chrysler 300 Mechanical Problems and Questions 10 10-04-2008 05:10 PM
anyone done the "big 3 wire" upgrade? unibomber 1st Gen Chrysler 300 12 04-06-2008 07:18 PM
» Advertisement
vB.Sponsors
=Gigathreads Network=
DIESEL Diesel Forum
CHRYSLER Chrysler 300C Forum
JEEP Jeep Forum
PONTIAC Pontiac G8 Forum
